![]() | Home > Group Buys > IID Tool - Bluetooth - £365 delivered |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4444 ![]() ![]() ![]() |
Currently being run on D3. We have our minimum of 10 units, if anyone on this side is interested
Mikey is running another group buy, same as the last one, if anyone is interested. |
The minimum 10 people required has already been met now, but still room for more. |
You can get details of coverage here: http://www.gap-diagnostic.com/products/iidtool.html
A bit more info, for anyone sitting on the fence
Height Calibration ![]() Module/Sensor/Height calibrations ![]() ![]() ![]() ![]() Service/Test Menu, offering Key Programming, Service Interval Reset, Aux Heater prime and Operation Check, EPB Unjam function, Lift Pump Security Reset, Suspension valve testing, and Transmission Adaptive Reset ![]() ![]() ![]() ![]() It offers Live Values, both in digital, and graph form The graphs are invaluable for pinpointing intermittent faults, as you can see the specific rise/fall in readings, instead of the digital values ![]() ![]() ![]() It offers "Safe" CCF Editing ![]() ![]() ![]()
It also offers "Advanced" editing. For 99% of owners, this option will go unused, but it can be made available for anything you want to retro-fit, or enable. This is where the CCF Restore function is invaluable ![]() ![]() ![]() ![]() ![]()
ECU Flash screen. All of these Firmware options are free to use. There is a small charge for Firmware not listed in this menu, and is supplied direct from GAP. ![]() The ECU Info tab allows you to see modules which are fitted to the car and what firmware is currently installed. Invaluable if you are having module communication issues The Save/Restore tab allows you to save your specified height requirements, and change to them in a matter of seconds, as well as the CCF Restore, just in case ![]() ![]() Considering a main dealer will generally charge a minimum of £100 for a diagnostic plug in, the IIDTool offers excellent value for money, and while the saving is not huge, its better than nothing ![]() Last edited by Disco_Mikey on Mon Aug 31 2015 3:48pm. Edited 1 time in total |
Looks good but ive got a snap-on modis running 15.2 software which will do most of what I need.
PhilMid Member Since: 14 Aug 2015 Location: Hull, East Yorkshire Posts: 61 ![]() ![]() ![]() |
Im interested.
Phil, join DISCO3 and get yourself signed up to the group buy. I presume Mike will send out payment instructions once it's ready to go ahead. |
Couple more days to go for anyone still thinking about it. Closes on Sunday. |
Last chance to sign up today, chaps. |
As it stands, we have 17 signed up, so the buy will be going ahead
