![]() | Home > Maintenance & Modifications > Exhaust change? |
D6EML Member Since: 30 Jul 2015 Location: West lothian Posts: 124 ![]() ![]() ![]() |
Yes mate you can buy the exhaust finishers which will improve the look of your car from behind instantly 👍 make sure you order the diesel type if you have a deisel model. Your original tailpipes are still in use as the exhaust finishers are just cosmetic . Try eBay or powerfuluk
kostaslv Member Since: 22 Sep 2015 Location: Bedfordshire Posts: 3 ![]() |
Hi to all. Upgraded my 2011 sport to autobiography body kit, but experienced a little problem with the exhaust tips. My car is a diesel model but with the straight exhaust pipes like on the petrol version. Bought tips for the petrol version but they do not fit as they are 60mm in diameter but my original exhaust pipes are 65mm. Does anyone know where to get autobiography tips but with at least 66mm in diameter pipe at the connection point?
tone 123 Member Since: 18 Dec 2014 Location: northeast Posts: 36 ![]() ![]() ![]() |
hi came up against this problem at the weekend. tailpipes 60mm exhaust 65mm iv got genuine autobiography tailpipes petrol. my car is a supercharged so what i have done is order some adaptor reducer sleeves about £20 of ebay have a search. |
Thanks. did you have to cut(shorten) your existing ones at all? Obviously the adaptor would make original ones a bit longer.... |
Buy the deisel ones and cut your exhaust back leaving enough space to clamp the AB tips on
hi yes had to be cut. some seem to get away with just cutting the exhaust and the tips fit on. but mine did not like you my tailpipes were 5mm to small so had to go down this road. |
