![]() | Home > Maintenance & Modifications > Change my excaust and got the massage"DPF full see hand |
bazz6666 Member Since: 03 Mar 2014 Location: Thessaloniki Posts: 40 ![]() ![]() ![]() |
You think so!
With a turbo going it could last weeks/ months or it blow pulling out of your drive tomorrow it's impossible to say. It might be worth getting your mechanic to check for sticking actuators though, cheap and simple fix if they free off. Check fault codes.. 2008 G4 RRSport TDV8 current
I took the car in today to had it checked.This is an indepentent mechanic.
I had attached a LR diagram with the actual tube and Rubber I had described above
