Home > Technical > Command shift. |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2011 |
In D or S ?
Wed Aug 26 2015 7:45pm |
In both DrRob,,command shift works in D & S unless lights are on then I can only gear down.
Wed Aug 26 2015 7:50pm |
jeffhunt Member Since: 19 Oct 2014 Location: Hayling Island Posts: 83 |
is that using the flappy paddles behind the steering wheel.?
Thu Aug 27 2015 5:44am |
Tks Jeff,,ill try that later,,its just weird they work fine without lights on but don't with lights on.
Thu Aug 27 2015 7:51am |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
Thinking this could be a case of the same issue that occurs with the older vehicles. On the older vehicles, there's a wiring splice under the front of the passenger sill that corrodes (purple/blue wire), causing loss of sport and command shift when the sidelights are on. Would be interesting to hear if this fault happens to the 8 speed.
Thu Aug 27 2015 8:11am |
ive pulled it into my workshop to check it out now,,i will keep you all informed on progress.
Thu Aug 27 2015 1:00pm |
Had the paddle off & that doesn't make any difference.....so next step is wiring.
Thu Aug 27 2015 3:13pm |
Well ive fixed it,,even though it was the right hand paddle to gear up it was the conection on the left paddle that needed cleaning.
Thu Aug 27 2015 3:31pm |
Cheap fix. Did you put WD40 in it? It kept recurring for me until I put a good squirt in. |
Thu Aug 27 2015 3:50pm |
I used some clutch & brake cleaner on the left one.
Thu Aug 27 2015 4:50pm |
