Home > Technical > 2010 autobiography seat heating?
RRSCS
Hungary 2010 Range Rover Sport 3.0 TDV6 Autobiography Santorini Black
Hi Folks,
I am intending to buy a 2010 (december) autobiography sport and I am wondering whether it can be that it has no seat heating, since the climate control panel does not have the switch? I attach the picture here (I have not seen the car yet in real)
By the way, I could not find the owner's handbook on LRTopix site with this climate control panel. I saw ads on the Net that cars are sold with this climate control panel saying that seat heating is installed.
Any input is well appreciated.
Thanks, Best,
RRSCS
Post #470916 Sat Aug 22 2015 7:40am
ABSport
United Kingdom 2011 Range Rover Sport 3.0 TDV6 Autobiography Santorini Black
Hi All Range Rover Sports from 2010 onwards front seat heating is standard. From HSE upwards to the Autobiography the rear seats are also standard equipment. Climate control is also standard. The climate is part of the heater and air-con. So if your looking at an Autobiography then YES climate and front and rear heating will be there. Thumbs Up
The picture you have posted clearly shows the front heated seats switch for both front seats. The rear switches are situated in the rear of the centre consul.
Post #470932 Sat Aug 22 2015 11:55am
JasM
Scotland 2012 Range Rover Sport SDV6 HSE Orkney Grey
That car definitely doesn't have heated seats, if you look carefully you can see the heated seat buttons are missing.
Standard spec of LR's varies in each country, for eg. a HSE RRS from Spain won't have Cold climate pack fitted whereas on a UK spec HSE RRS it comes as standard. 2014 L405 SDV8 RR Autobiography Cool
2012 RRS SDV6 HSE -Orkney Grey with A/B bodykit - Now Gone Sad
2007 RRS TDV6 HSE - Zermatt Silver - Gone
Post #470936 Sat Aug 22 2015 4:21pm
RRSCS
Thank you very much, for both of you.
JasM: That what I was afraid of. However, in earlier models, sometimes the heated seat switches were missing from the climate control panel and were installed on the seat itself. That is why I was curious.
Anyway, I have to contact the seller to sort this out.
Also, it was strange that the owner's handbook I found does not show that climate panel I have on the picture, it should somehow indicate the differences.
Best, RRSCS
Post #470940 Sat Aug 22 2015 5:52pm
