Home > Technical > Awaiting the verdict
michaelsanderson
England 2011 Range Rover Sport SDV6 HSE Fuji White
Well Lorek is in at LR Wakefield and i'm awaiting some verdicts.
Currently, the drivers door doesn't lock and the suspension has an intermittent fault where i get 'normal height only available' on the dash. Turning it off and back on again cures it of the suspension issue and i can change the height again. Every time.
I'm hoping that both of those problems are failures of parts so they're covered by my warranty direct policy and that it pays out quickly and is straight forward.
Will report back on all counts... after a battery last weekend (which annoyingly doesn't fit properly because it's slightly wider at the bottom than the old one - so I cant get the strap on as the threaded hole is partially covered by the battery), it's going to be an expensive do!
Post #470172 Wed Aug 12 2015 12:57pm
michaelsanderson
So here's the shout...
The door isn't locking because it needs a new latch, which contains the broken actuator.
Over 400 squids plus VAT in total.
The intermittent suspension fault is due to a compressor failure, which is more expensive than the first one.
WD asked the dealer for MOT cert, last service invoice and service history. The only one of those they had was the service book and a pic of the mileage from the dash. WD accepted this and authorised both jobs, LR had both parts in stock and i'm getting it back in the morning.
Well done to both Guy Salmon Sytner LR Wakefield, and Warranty Direct for making that fairly painless. I say fairly because LR aren't an approved repairer, and so I will have to pay for it and then be paid back by WD, which will be quite a sting for the amount, but i'm just pleased it's all sorted and I'll get it back less the excess.
After these jobs, a battery last weekend, a new boot latch after that failed, here's hoping that it behaves for a while!
Post #470206 Wed Aug 12 2015 8:45pm
Tyrefitter
They are good at Guy Salmon Wakefield,,I'm on my 4th vehicle from them 1st one being a 2002RRFF,2nd a RRS TDV8 2007,3rd RRS TDV8 2008 & now my 2012 SDV6.ive only had a couple of probs with my first 3 cars which was sorted under warranty straight away.
Andy Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #470208 Wed Aug 12 2015 9:09pm
Bodsy
Site Sponsor
That's a great result. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #470210 Wed Aug 12 2015 9:20pm
drdelrrs
You'll see several posts on here about batteries.
I think you'll find the general view is that these cars are pretty sensitive to non-identical batteries which can lead to fried alternators and other gliches.
I'd get an original spec. unit fitted.
Post #470282 Thu Aug 13 2015 4:57pm
Disco_Mikey
�400 + VAT for a door latch? Shocked
The part retails at �90 + VAT. And it's an hour to fit. That's a huge hourly rate Neutral
I hate to think what they quoted for the compressor...
Post #470284 Thu Aug 13 2015 5:13pm
Lost for Words
No need for a Genuine battery, just as long as it's a good one. (Recommended option: https://www.tayna.co.uk/EA1000-Exide-Premi...-7488.html) Thumbs Up
OE alternators (Denso) are a must, however (but it still doesn't have to be LR branded, of course). Wink Visiting from DISCO3.CO.UK
Post #470287 Thu Aug 13 2015 5:35pm
