Home > In Car Electronics > Heated Rear Screen only working on bottom |
savi18 Member Since: 02 Aug 2015 Location: Gore. South Island NZ Posts: 145 |
Hi All, Only had this 2009 RRS for 2 weeks and have multitude of faults with it, this post is to do with the rear screen, it was iced up this morning so used the heated rear screen button for the first time, and only the bottom 2 heater wires heated up, rest of screen frozen solid, if there is a break further up the screen is there a repair kit to fix. Cheers |
Wed Aug 12 2015 9:13am |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1067 |
Does the same happen if you use the "program" button instread - I find it works best.
Wed Aug 12 2015 10:29am |
It its frozen again 2morro will try the prog button. If not it's out with the test meter this weekend. Cheers |
Wed Aug 12 2015 11:13am |
Are these rear screens laminated same as front or do they go into thousand of pieces when cracked/smashed, Cheers |
Thu Aug 20 2015 6:14am |
Before you go smashing the rear screen with a hammer you might want to check the battery condition as low charge results in the battery management system not permitting operation of the rear screen heater. Another frequent problems is a corroded connector in the wiring under the spoiler - use the search function to find a detailed description of DIY fix. 2008 MY Java Black TDV8 HSE
Thu Aug 20 2015 8:13am |
No Intension of smashing the glass, the rear glass will be changed free of charge by insurance company as this could be a safety issue I think, its just when they take it out what will happen, Cheers |
Thu Aug 20 2015 8:28am |
