Home > General (L494) > New Pirelli SUV Zero size for 22 inch rims.
Disco
http://www.pirelli.com/tyres/en-gb/car/fin...size-range
This is for on road only.
Not many of us will need new tyres yet but worth a look when we do.
Post #434640 Sat Aug 30 2014 5:41pm
DaveW
The only thing I'd say is that the 285 and 295 fittings for the Asimettrico (I assume that's the tyre you're looking at) won't work on an RRS for two reasons.
Firstly they aren't strong enough from a load rating perspective (ours are 108/110/112) which will screw your handling and secondly the sidewalls are way thinner than they need to be. You can expect rim damage first pothole or kerb you come across. Your RRS will feel anything but sporty on tyres that move around like I'd expect those to.
Also, because they are outside our recommended 2.5% tyre diameter limit, your gearing, speedo and everything linked to that will be out of kilter.
The 305s won't fit on the 9.5J rims and even if you did, you'd need spacers and I'd suggest seeing the other thread on that one.
Post #435344 Fri Sep 05 2014 4:13pm
Disco
No it is the same 275/40 as the conti tyre. Same load rating as well.
The P Zero SUV.
Post #435365 Fri Sep 05 2014 6:09pm
DaveW
Ah yes, found it thanks.
Post #435409 Sat Sep 06 2014 8:21am
Disco
http://www.blackcircles.com/order/tyres/search
If this is right, that is nearly 100 quid less than the Conti. And two db quieter, which will be good.
Post #447182 Fri Jan 02 2015 5:25pm
Disco
These are now std fit.
http://www.pirelli.com/tyre/au/en/news/201...ver-sport/
I wonder what the cost will be?
Post #469673 Thu Aug 06 2015 12:01pm
Tyrefitter
ive just fitted 285/35R22 PIR SCORP ZERO 106W XL to my12 RRS.
Andy Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #469689 Thu Aug 06 2015 1:53pm
