Home > General > Upper tailgate issue |
designboy Member Since: 03 Feb 2014 Location: whitehead co antrim Posts: 338 |
easy fix mate just done it on mine, careful as it can run your battery flat. Water ingress kills the motor the garage showed me it and it was amazing! It costs 28 quid for the part, you could fix yourself or about 30 quid labour. I'm sure you can google it. |
Tue Aug 04 2015 5:54pm |
monty19 Member Since: 12 Mar 2014 Location: boro Posts: 323 |
Update, I'd noticed it was doing when the key was put in the ignition, so I checked it and all is ok, no corrosion no water , and everything was lined up up, so I tried this.
Wed Aug 05 2015 12:52pm |
