Home > Maintenance & Modifications > Heavy black smoke when Turbo cuts in - split pipe? |
GrahamS Member Since: 04 Apr 2013 Location: Wigan Posts: 18 |
I had clouds of black smoke and it was indeed due to a split intercooler pipe (the one on top of the 2.7 V6). |
Sun Aug 02 2015 4:26pm |
Ptang Member Since: 11 Jan 2008 Location: Bromley, Kent Posts: 95 |
Thanks GrahamS...
Sun Aug 02 2015 7:57pm |
I didn't actually do it myself as I had the car in for new front wishbones too. |
Sun Aug 02 2015 8:41pm |
I'll try to dig out the invoice for the p/n. |
Sun Aug 02 2015 8:43pm |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
Yes, that's the correct PN for the main hose, but I'd suggest you buy a set of silicone ones. Easy as pie to replace the main hose. 2 jubilee clips and 4 plastic rivets. The left-hand, large one is not too bad, the little one is a PITA. The main one is the most common failure, though the others have been known to fail. I'd also suggest you get on and blank your EGRs - Easy enough to do and no software changes required. Guide: http://www.disco3.co.uk/gallery/albums/use...0SMALL.pdf
For future referrence, you don't even have one. Visiting from DISCO3.CO.UK 2006 Discovery 3 TDV6 Auto HSE Zambezi Silver |
Mon Aug 03 2015 8:05am |
Thanks for all the advice.
Tue Aug 04 2015 8:04pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4395 |
Rivets should be ANR2224 |
Tue Aug 04 2015 8:42pm |
Perfect - thanks DM. |
Wed Aug 05 2015 9:01pm |
Bladeboy Member Since: 17 Sep 2013 Location: Benson Posts: 522 |
When this happened to me I replaced all the hoses (except the small one) with silicone ones, and had the EGRs blanked, but the problem was a split in the outer casing of the inter cooler. |
Fri Aug 07 2015 10:44pm |
