Home > General (L494) > Dynamic mode |
alexv Member Since: 02 Mar 2015 Location: beds Posts: 51 |
I will answer your first question.
Thu Jul 30 2015 6:07am |
aks Member Since: 13 Jul 2015 Location: Hertfordshire Posts: 21 |
Thanks, that's what i thought. And, I understand it won't 'stay' in dynamic mode between starts, it always reverts back to normal mode (it's what my BM does). Is this assumption correct? Tony |
Thu Jul 30 2015 12:18pm |
Fletcher Member Since: 28 Jan 2015 Location: Devon Posts: 481 |
I've only had demo cars for weekends but oh my word, it's really good, it's a proper sport mode that transforms the car when you want to make good time / push on ( give it the beans ) |
Thu Jul 30 2015 12:24pm |
Hodog16 Member Since: 10 May 2015 Location: North Carolina Posts: 64 |
I believe it has to be turned on each time.
Thu Jul 30 2015 10:25pm |
Renaco Member Since: 28 Jul 2011 Location: Bavaria Posts: 324 |
The dynamic mode has to be turned on every day and then it stays for the next restarts (only if they are min. 4 hours of not using the car it resets to standard mode). |
Fri Jul 31 2015 9:59am |
Thanks for the video link. A significant reduction in body roll, so that seems like the way to go without doubt. Tony |
Fri Jul 31 2015 3:30pm |
If RRS2's Dynamic system is anything like the Evoque's then it operates all the time, regardless of the setting being selected or not. What happens when you select the dynamic setting is the suspension, steering (remember it is electronic power asistance not hydraulic), throttle and gearbox ECU's all get remapped to give "sportier" handlingthan in standard mode. Ther big difference between Evoque's system and RRS2's is the suspension Evoque has Magneride, RRS has the airbags. The change to Dynamic setting in the RRS is much more noticable than it is in an Evoque Dynamic whether is is because on air springs and being a high car the "tied down" feeling is more noticable in the RRS than the low slung, harsher suspended Evoque I don't know. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Fri Jul 31 2015 8:41pm |
bermyandy Member Since: 09 Sep 2007 Location: London Posts: 336 |
Is the torque vectoring always on? Also, is that only an option on the Dynamic and above, or a feature of the new sport in general? |
Tue Aug 04 2015 10:10am |
torque vectoring is always ready to be "on" but mostly not in use, means "off".
Wed Aug 12 2015 2:05pm |
JSR2014 Member Since: 10 Feb 2015 Location: Kent Posts: 341 |
Its quite a strange feeling when you feel it working (Torque Vectoring).
Wed Aug 12 2015 4:11pm |
Keeno Member Since: 08 Oct 2015 Location: Tunbridge Wells, Kent Posts: 3 |
interesting, sorry to resurrect an old post...my local dealer was very adamant that i wouldnt notice the difference, which is contrary to the opinion of friends and comments here. I suppose i need to test both back to back. Is it me or have i seen more brand new standard HSE's around recently? maybe the finance deals on low spec entry level cars are attracting people out of buying Disco's etc etc.. currently D4 HSE 2013 SDV6, 1986 911 3.2 Carrera.. |
Thu Oct 08 2015 2:07pm |
malcolmw Member Since: 05 Dec 2013 Location: United Kingdom Posts: 122 |
I think there is a simpler explanation. The standard HSE corners light years better than the old model so upgraders who don't need the last bit of cornering performance think the standard car is fine. Most people will not need the Dynamic potential for the school run and as it costs, say, £5K then what is the point?
Thu Oct 08 2015 2:37pm |
I must admit, when I first took delivery of my 14.5 L494 I could not notice a difference in the steering weight whilst using Dynamic vs Regular.
Thu Oct 08 2015 2:55pm |
fkarim Member Since: 14 Apr 2012 Location: London Posts: 2216 |
Switching to Dynamic Mode in RRS1 made a big difference in ride quality. In RRS2 I can notice the difference (probably because I am paying a lot of attention) but it is very slightly "less comfortable" in dynamic mode than in normal and still absorbs road imperfections brilliantly. Handling is undoubtedly improved in dynamic mode. I do agree that most people do not need that extra sharp cornering on a day to day basis. It will however truly demonstrate this capability when driving "properly" on twisty country and mountain roads. Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top
Thu Oct 08 2015 3:16pm |
