Home > Maintenance & Modifications > 80k service report (extended warranty)
Cooperm28
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
Sorry there is mutiple posts regarding warranties etc but got a few questions regarding my recent 80k service health check report.
The car is a 2010 RRS HSE with only 35k, ive just renewed the LR approved warranty. Would the following items be covered under the warranty as they came back as advisories after the service but not sure if they will bump it off as "Wear & Tear"
1. Both rear tie-rods worn advise replacement £267.65
2. Both front lower wishbones have worn bushes causing knocking under braking , advise replacement withnuts and bolts £851.46
3.osf lower ball joint has play £150.82
Post #468857 Tue Jul 28 2015 6:05pm
It's got to be worth asking them but my pound would be on them refusing the claim.
You should be able to knock £££ off those prices if you find a decent indie. Note that the lower ball joint is included with the new lower wishbone (unless I'm getting my joints confused). 2012 SDV6 - it's missing a couple of cylinders
Post #468863 Tue Jul 28 2015 7:33pm
