![]() | Home > Technical > Newbie without an Owners manual. |
Deuchars Member Since: 26 Jul 2015 Location: North Wales Posts: 38 ![]() ![]() ![]() |
I've just bought myself an RRS SC, because I wanted a bit more comfort than my Nissan Navara was giving me and I'm very very happy with it. But one little thing thats annoying me is the Info display in the middle of the dash Not showing the time in the top left corner. The time is set on the stereo display. Anyone out there know how I can fix this as it's really bugging me seeing --:-- on the dash in front of me............ |
Disconnect the battery, or failing that, try a hard reset. |
Thanks for your reply, I can disconnect the battery easily enough, but how do I do a hard reset? |
sharpieRRS Member Since: 24 May 2015 Location: Blackboys Posts: 8 ![]() ![]() ![]() |
you might be able to also download an Owners handbook from the LR website - they are identical to the paper version.
Thanks, I tried that, it put me onto Topix, but wouldn't let me print or save the info..... |
Yes, I got directed to Topix too, fortunately i was able to download mine |
itsmeagain Member Since: 01 Nov 2012 Location: Birmingham Posts: 222 ![]() ![]() ![]() |
Heres a link for an online version, hope it helps
http://www.disco3.co.uk/wiki/Hard_Reset ![]() 2006 Discovery 3 TDV6 Auto HSE Zambezi Silver ![]() |
Ok, so i've done the hard reset. did a bit of tlc under the bonnet while i was at it. Clock is still not working just see --:-- where it should be......... |
How's the battery? It can be one of the first signs of failure. |
It wasn't fully charged when i tested it. I put it on the charger for an hour or so to top it up before i reconnected it. It was fully charged when it was reconnected and the same thing happened, no clock....... |
Perhaps try the hrad reset once more, but otherwise, I'm not sure what's next. |
Success at last. One more hard reset and a new battery have sorted out the clock issue on the dash. Should of realised the battery was on its last legs, as it was the original Land Rover one!! 2008 Supercharged Stornaway Grey, 22inch black Stormers
