![]() | Home > Technical > Gearbox adaptions |
Has it had a proper oil flush and the codes read? Visitor from fullfatrr.com
The gearbox adaptions allow the gearbox to accommodate its own internal wear as well as the driver's style. Clearing the adaptions will set it back to the settings it had as a wear free unit. This is presumably why yours is now throwing errors because it think things are out of tolerance. 2012 SDV6 - it's missing a couple of cylinders
Radioham 49 Member Since: 05 Jan 2015 Location: Maidstone,Kent. Posts: 9 ![]() ![]() ![]() |
Thank you for your prompt reply.
RRSTDV8, thanks for your help. Do you know if the gearbox changes will improve with time or have I messed it completely ? |
A flush is recommended for all gearboxes with a bit of age and mileage. Visitor from fullfatrr.com
You may have killed your gearbox...
No idea, sadly. It might be worth speaking to someone like Bristol Transmissions who have a good reputation with this gearbox.
Car has done 123 k miles. I wish I had left the adaption reset alone, too late now |
Can you tell me if Bristol Transmissions are the best or is there somebody as good that is closer to Kent?
You need to reset the adaptions once more, then drive the car very gently for the next 2-300 miles.
Disco-Mikey many thanks for your help. I will reset again tomorrow & drive it as you recommended. |
Adaptions reset again as suggested.Able to drive the car in command shift. Have to back off the throttle when shifting into 4th gear (original fault). Have provisionally booked car into Bristol Transmissions & will travel down overnight when less traffic is about. Does anybody know if once 6th gear is selected will it stay there for the duration of the journey if the road speed is high enough. |
If you can keep it at a reasonable speed then it should stay in 6th. It'll change down even in Command Shift but not until about 50mph (a guesstimate from hazy memory). On a fast A-road or m-way it should be stay in 6th. 2012 SDV6 - it's missing a couple of cylinders
Many thanks for your help. |
