Home > General > Water in rear tyres
Silvermercf1
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Water in rear tyres
I have a 2013 sport 20"wheels old style.
I have had issues with water in the rear tyres causing unbalance and vibration through the car.
Anyone had this problem? How can I stop this happening?
Post #468476 Fri Jul 24 2015 7:58pm
Marvik125
nitrogen filled sealed tyres
Post #468494 Fri Jul 24 2015 11:13pm
Stecla
England 2010 Range Rover Sport TDV8 HSE Stornoway Grey
I had the same problem in the fronts. I think it's an issue with the Pirelli tyres. I suspect the answer is as above.
Post #468496 Sat Jul 25 2015 4:54am
braveheart20
Scotland 2012 Range Rover Sport 3.0 TDV6 HSE Fuji White
Hello
Hi there I had the same issue went back to land rover due to the excessive vibration. Transpires it was water inside one of the rear tyres land rover dealer tried to charge me for the work.
The vibration was that bad the plastic cover on the underside of the car had vibrated loose. I suspected a problem with there compressor when they were assembling the trees on the wheel
They claimed I must have changed a tyre. I called there bluff and said I would take the serial numbers of the tyres and they can check on the Bach numbers of tyres.
Haven't had any problems since they bailed the water out my Range Rover.
Brave My 2012 RR SPORT in white
My 2010 SLK AMG in white
My 2012 Quadzilla rs8 In white
My 2012 Mini countryman in white
Post #468508 Sat Jul 25 2015 8:47am
Moog2014
United Kingdom 2012 Range Rover Sport SDV6 HSE Lux Fuji White
Have a look here :
Home > Wheels & Tyres > Water in tyres. Any ideas why ?
We came to the conclusion it's a bad compressor.
Post #468548 Sat Jul 25 2015 7:30pm
Silvermercf1
Thanks for the feed back.
Just to expand, the car is just under 2 years old and the tyres are the factory fitted set. I have had to have the water removed and rebalanced twice in the last two years.
Land Rover Stratstone's response was " they have never heard of the problem previously. "
I have not topped up the air pressure in that time as the tyre pressures have always been okay.
Post #468641 Sun Jul 26 2015 6:37pm
Do you pressure wash your car? Perhaps it's done when serviced? Get a pressure washer jet up against the beading and I bet you'd force some water in. 2012 SDV6 - it's missing a couple of cylinders
Post #468648 Sun Jul 26 2015 7:27pm
CRC@LandRover
Hi Silvermercf1
Thank you for your post.
I note your comments and would be happy to speak to your retailer to establish their findings.
Should you still be experiencing a concern and wish for me to look into this, please feel free to contact me via PM and I will be happy to assist.
Regards
Ryan Please note although Land Rover will try to assist you with your issue, we are unable to provide any technical advice. This account is available between 0900 and 17:00 hours Monday – Friday. Outside of this time if you require assistance, please drop us a Private Message and we'll get back to you.
Post #469315 Mon Aug 03 2015 11:26am
PWW
United Kingdom 2013 Range Rover Sport SDV6 HSE Orkney Grey
Had the same issue.
2013 With 20" Pirellis first year no real problem noticed.
After first service had a vibration which felt like coming from middle of car.
Took to get rears balanced and tyre fitter had issues trying to balance rear offside.
After several attempts they took tyre off and had about half a litre of water in there.
Rebalanced and all ok.
Coming upto winter car had a vauge feeling to the front end.
Fitted 19's with winter tyres and car felt fine.
Refitted 20's after 2nd service in March and Vauge feeling returned.
Decided to fit 4x new tyres even though 3mm on front and 4.5mm on rears
Tyre fitter found water in front offside tyre.
Four new pirellis fitted since march and no issues so far.
Vauge feeling also gone. 2013 HSE Black Edition, Orkney Grey, Ivory Trim, Exterior design Pack and Privacy glass
Post #469338 Mon Aug 03 2015 4:08pm
