![]() | Home > Technical > Ctek Chargers and Flat Battery |
It takes a very long drive for the battery to actually charge fully, so a good charger is infinitely preferable.
B9BS X Member Since: 19 Nov 2014 Location: Birmingham Posts: 420 ![]() ![]() ![]() |
Just need to get the car going as ive got a long drive ahead next week but do want it to start up again for on the way back |
muddywheels Milk Float Man Member Since: 30 Jun 2010 Location: East Riding of Yorkshire Posts: 5637 ![]() ![]() |
The bigger the CTEK the faster it charges so the longer the vehicle stands unused the smaller the CTEK needed - I bought the MX 5.0 and used it during winters with no problems |
Bearing that in mind muddywheels might be better to buy the mx 5.0 and save abit of cash |
Though, extra power could save your rear bumper if you ever forget to put it on charge! |
The CTEK MX5.0 - is a smart charger and as such goes through a series of processes as required to charge the battery. While it will charge the car I think 5 amps is a bit small for a RRS battery (though it is within the CTEK 5.0 specs). After charging the battery it should go into maintenance mode which is essentially a trickle charge and just keeps the battery charged.
Any idea how long a ctek mx5 charger will take to fully charge a very low battery?
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2795 ![]() ![]() |
Took my CTEK MX5 approx 12 hours to run through its phases |
Handbook shows the time as follows -
Battery must be min 2v or CTEK will not commence charging ![]() http://www.ctek.com/Archive/ProductManualPdf/MXS%205.0_EN.pdf Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW Still hoping for a S2 one day! |
Cheers guys
I would go for a CTEK MS15 07MY RRS TDV6
Does the CTEK MS15 charge quicker? RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
The number in the model is the max amps the charger can deliver - the mx 5 can only ever deliver a max of 5 amps even though at its state of charge the battery may be able of accepting more.
Thanks garrycol RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
