Home > General > Colliers Land Rover Birmingham |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2792 |
I have visited there a few times - always busy & polite when I have been spoken too but ( time & distance allowing ) I would drive it back to them & kick it off 16MY Estoril Blue SVR.............
Tue Jul 07 2015 11:12am |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
Not necessarily; I wouldn't be worried about it unless I found a time stamped fault code that they should therefore have seen. These cars do throw up faults without warning. With a two year warranty, they'd have nothing to gain by it anyway. Visiting from DISCO3.CO.UK 2006 Discovery 3 TDV6 Auto HSE Zambezi Silver |
Marvik125 Member Since: 02 Jul 2015 Location: West Midlands Posts: 139 |
I will see what LR Assistance say, I really do like the car though. I will give them a fair chance before screaming at them. I did some research before buying a used RRS so I knew the chances are it WILL go wrong at some point. Hence I went to a main dealer with the 2 year unlimited mileage warranty an 2 year LR Assistance. If this was a side of the road forecourt I would be in a mild panic about now. But I'm not worried "yet" |
Tue Jul 07 2015 11:15am |
I agree with what you say & as already mentioned if the fault as no historic codes then it`s pure bad luck If it was sold with a faulty component / components then that is clearly not right. The last thing you want is your new pride & joy being dragged away to be fixed
Tue Jul 07 2015 11:26am |
The most likely causes of such a fault would be a bad suspension calibration, faulty height sensor (or wiring) or perhaps a restricted air pipe/blocked air drier or similar. Visiting from DISCO3.CO.UK
Tue Jul 07 2015 11:39am |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2011 |
I'd just ask them nicely to check it over. I too have just bought a 2012 model and have had them do a couple of niggles - all for nothing. Not from your dealer though. Just be polite but firm Visitor from fullfatrr.com
Tue Jul 07 2015 1:29pm |
The Bad- Its having a new compressor fitted Monday. Also exhaust mentioned, but not the engine exhaust.
Tue Jul 07 2015 2:15pm |
Result. Its what you pay a bit more for via a main dealer. Use the services offered to the full
Tue Jul 07 2015 2:54pm |
Excellent. If the compressor doesn't exhaust correctly it can certainly have that effect.
Tue Jul 07 2015 3:01pm |
Good result faith restored
Tue Jul 07 2015 6:15pm |
Wasn't sure when they started fitting them... Are they a lot more robust and reliable than the Hitachi? Visitor from fullfatrr.com * GONE. 2012 RR Sport HSE SDV6 Orkney Grey. Now being piloted by RRSTDV8 * GONE: 2011 4.4 TDV8 Full Fat. Amazing piece of kit. * Current. 1974 Lightweight 2.25L petrol. Old skool * GONE. Freelander GS TD4 Manual MY2013. Orkney Grey with privacy, cold and clearview packs, armrests (a must!) and a spoiler. * GONE. Range Rover Classic '93 200Tdi Factory fit * 1949 80" in family since 1975 |
Tue Jul 07 2015 8:29pm |
No faith restored just yet, I will report back next week. Worth mentioning Colliers only involvement so far has been to sell me the car then tell me to ring Land Rover Assistance when I had a problem. An LR Assistance has booked the car into Shukers in Shrewsbury (closer to me). I guess Colliers 165 point check is lacking slightly, as the exterior trim on the bottom of the driver and passenger front doors is loose. I won't be buying the clips Colliers will. |
Tue Jul 07 2015 10:07pm |
Brother uses Shukers - good service, been around for yonks.....
Wed Jul 08 2015 7:48am |
They've certainly proved to be a vast improvement over the Hitachi. I believe they switched to them during 09MY. Visiting from DISCO3.CO.UK 2006 Discovery 3 TDV6 Auto HSE Zambezi Silver |
Wed Jul 08 2015 8:05am |
