![]() | Home > Technical > heater fan problem |
airwolf222helicopters Member Since: 25 Apr 2010 Location: kent Posts: 248 ![]() ![]() |
anyone??
Sorry but no good ideas to offer. You can see the fan assembly if you drop the lower glovebox by pressing down on the supporting arms. Look online for a video on changing the cabin filter to see how this is done. I'd guess any ballast resistors to control fan speed are incorporated in the HVAC unit. There is a self test routine for the HVAC you can invoke: searching the site should find the instructions. 2008 MY Java Black TDV8 HSE
Thanks for reply paddy
Forgot to say I wont be able to tell if it is the solution until I get a replacement tommorow |
Top work. Looks as if you have tracked down the problem. 2008 MY Java Black TDV8 HSE
bl74beano Member Since: 08 Sep 2013 Location: Perth Posts: 74 ![]() ![]() ![]() |
Hey Airwolf I seem to have the same problem did your fix work? |
