Home > General > 2010 RRS Exhaust Smoke
Robsrr
Australia 2010 Range Rover Sport 3.0 TDV6 SE Siberian Silver
I am new to the forum.
I have 2010 RRS 3.0 TD V6.
Last Friday night coming home from work I pulled up a set of traffic lights after travelling about 5km from work and lots of blue oily smelling smoke started coming from the exhaust while idling at the lights. I pulled over and shut the engine off figuring a turbo had problems. I started it after a few minutes and the smoke was a lot less so I drove it home (about another ten kms). When I got home there was hardly any smoke. I took it for decent run the next day in traffic and on the freeway and no smoke from the exhaust at all.
There is no drop in power.
Any ideas?
Thanks in advance.
Robsrr
Post #466561 Sun Jul 05 2015 1:14am
codfather
Scotland 2010 Range Rover Sport 3.0 TDV6 SE Santorini Black
Does yours have straight exhaust pipes? If so, sounds like the diesel particle filter was just doing its job. It needs a good run every so often to 'clear its throat'
I would be worried if it was happening all the time
Dave MY10 TDV6 SE (debadged Wink ), Santorini Black, Flappy paddles, Privacy Glass, 20" Stormers, Mudflaps!
Gone: a comprehensive list of imprezas and a Merc ML AMG
Post #466612 Sun Jul 05 2015 5:50pm
Robsrr
Dave,
Thanks for the reply.
Excuse my lack of knowledge, what do you mean by straight exhaust pipes? The tail pipes or the exhaust pipe coming out of the headers.
Thanks again.
Rob
Post #466661 Mon Jul 06 2015 3:15am
garrycol
Australia
I didn't think Aussie RRS had the DPF back in 2010 but not sure. 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #466662 Mon Jul 06 2015 3:43am
codfather
Rob,
It's the short pipe coming out of the back box i mean. If it is swept downwards pointing to the road, you don't have a DPF. If it comes straight out it does.
They started appearing in late 2010, so quite possibly Garry is correct.
If you do mainly short journeys they cause more problems than they solve.
I hope it's that rather than anything more serious
Post #466732 Mon Jul 06 2015 5:54pm
Robsrr
Dave,
Thanks I will check.
It has not produced any smoke since.
Rob
Post #466942 Wed Jul 08 2015 1:43pm
Robsrr
Gents,
I have had the excessive (blueish) exhaust smoke problem fixed. The fix was a modification which moves the drain from the sump to the block so the drain is above the oil level in the sump. There is an LR technical bulletin for this, number is below.
I am a bit Censored the dealer did not mention it when I spoke with them. How I found out was via a local (Perth Western Australia) independent LR mechanic (Jordan Rover Tech) who were referred to me as being a good LR/RR mechanic, so since my RRS was up for service and needed the suspension compressor upgraded I booked it in. When I asked about the exhaust blueish smoke he said it most likely needs the sump drain pipe kit. It fixed the problem, no more blueish smoke on acceleration.
TECHNICAL BULLETIN
LTB00487v6
09 JUN 2015
Hope this helps others with similar problem.
Rob
Post #489689 Wed Mar 02 2016 8:11am
Mr Rusty
Scotland 2013 Range Rover Sport SDV6 Autobiography Fuji White
Rob
Thanks for the info.
Having exactly the same issue actually and taking it up with dealer as we speak.
Can i ask if this was fixed under Warranty? As Disco_Mikey said this was not a campaign (recall) and only done on customer request?
Thumbs Up 2015 RRS AB SDV6, Fuji White, Ivory
2012 RRS HSE SDV6, Sumatra Black and Ivory
Audi A5, 3.0 TDI, Gone
Audi TT, 3.2 V6, Gone
BMW 5 series tourer, Gone
Post #489707 Wed Mar 02 2016 10:22am
Robsrr
Chris,
Unfortunately not under warrently for me. It was around AUD550. The technical note state on the top of the second page Action: Should a customer express this concern, follow the Service Instruction below. So if your vehicle is still under warrenty they should fix it for free.
Rob
Post #489814 Thu Mar 03 2016 1:38am
Mr Rusty
Thanks Rob.
Glad u got it fixed. Shame it cost.
Thanks! Thumbs Up 2015 RRS AB SDV6, Fuji White, Ivory
Post #489828 Thu Mar 03 2016 7:50am
