![]() | Home > Faults & Fixes > Electric windows do not work anymore at front left and right |
rhenus132 Member Since: 13 Jun 2015 Location: Kaltenengers Posts: 34 ![]() ![]() ![]() |
Hi All,
No idea?
Disconnect the battery cables, then connect the cables to each other (OFF the battery) for 20 seconds.
i have read in other forums to short both cables for 10 minutes... i did that and no change...
Hold the window close button up and keep it closed for 20 seconds, may just need resetting home position. Bodsys Brake Bible
on both sides? i have problems on both sides
i am still struggling with that problem...
I just found out, that also the rear window can't be open...just the hatchback...
Problems is solved... |
tanloverluke Member Since: 19 Mar 2013 Location: Honiton Posts: 917 ![]() ![]() ![]() |
great news...how did you solve it ? Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
I found the electric drawings
jsrr Member Since: 31 Mar 2015 Location: Sweden Posts: 3 ![]() ![]() |
Hi.
Smartie Member Since: 31 Oct 2017 Location: Kummerfeld near Hamburg Posts: 6 ![]() ![]() ![]() |
Hi Rhenus 132,
