![]() | Home > In Car Electronics > gvif installation issues |
Is the remote button stuck on? Remove the controller battery.
sport2007 Member Since: 10 Feb 2015 Location: bt67 Posts: 41 ![]() ![]() ![]() |
thanks will try tomorrow and will come back with result |
hi there
Have you changed the dip switches to mute the other av channels? Bodsys Brake Bible
hi
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2795 ![]() ![]() |
Silly question - has the blue block connector in the back of the sat nav box under the seat either been dislodged or replaced the wrong way round - I had the same kind of issue |
hi there
Mine used to dislodge just moving the passenger seat fully back |
does anyone have the correct settings for range rover interface using only aftermarket wireless camera?
Follow the link - scroll down to he correct model - might help |
thanks Peachy have tried all these no good. it must be something simple I will look very stupid when we find out or I will go daft.
One last idea - try removing the fuse for the GVIF ( the one you allocated in the fuse holder in the glovebox ) then put it back - again i had to do it every now & then |
