![]() | Home > General > Short Distances |
It'll never warm up and the battery won't get much of a charge either. Two miles is a nice walk... |
Bradders Member Since: 08 Oct 2009 Location: Leeds Posts: 2515 ![]() ![]() |
That's one of the reasons I get rid of my TDV8. These cars need a decent run at temperature regularly. I work from home now so it would get much use at all other than the Sainsburys run……..and the 600 mile round trip to see our daughter at uni, once a term. FF 4.4 V8 Soooo looking forward to this bad boy
zaphod Member Since: 16 Jan 2015 Location: Liverpool Posts: 290 ![]() ![]() ![]() |
I've been doing a short commute like that for 20 years in a variety of vehicles and never had a problem engine wise. At this time of year it can be brutal on your battery though and especially so in the sport with all the extra electrical gizmos. So long as you are prepared to make sure that the battery is topped up every couple of weeks I'd say you'll be fine. I've fitted a permanently attached CTEK 'comfort' charging cable to mine so I can quickly hook up the battery charger once a fortnight to top off the battery with minimum effort. |
As zaphod says, keeping the battery topped up is ideal. I have an MXS25 so I can't use comfort leads but I intend to wire up some Anderson plugs. |
Ned Kelly Member Since: 03 Mar 2014 Location: Great Yarmouth Posts: 12 ![]() ![]() ![]() |
Cheers for the info. It will be a good excuse to the missus that I need to go out for a few hours at the weekend to run the motor.
npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716 ![]() ![]() |
granted a different car, but my old Freelander TD4 Auto had no issue at all with its half mile drive to work on a morning over 5 years, serviced regularly by LR and does longer runs through the day and after work |
Gornal Hills Member Since: 10 Nov 2014 Location: Dudley Posts: 380 ![]() ![]() ![]() |
Hi, mine does short trips all the while, but every 4-6 weeks it does an 80 mile round trip to our caravan, I believe this saves its life or certainly helps |
Half mile drive?! |
Sag Member Since: 07 Jul 2009 Location: Leicester Posts: 564 ![]() ![]() ![]() |
I work less than a mile from home so my 2.7 does a lot of short trips. Once a week I'll take it out for a 15-20 mile hoon down the dual carriageway to clear the cobwebs.
Also says "and does longer runs through the day and after work". Perhaps he/she didn't want to return home just to pick up the car for those runs. Could also be due to some medical condition. Otherwise I agree, that's just lazy ![]() Gone: MY16 RRS2 3.0 SDV6 Autobiography Dynamic, Carpathian Grey & Santorini Black Sliding Pano/Ebony & Ivory 2 Tone Gone: MY13 RRS 3.0 SDV6 HSE Black Edition, Orkney Grey/Ivory Gone: MY09 RRS 2.7 TDV6 HSE, Santorini Black/Almond |
I need my car through the day, for visiting the properties, clients and odd sandwich run, it would be a bit of a PITA walking home each time I wanted the car, so i drive, but occasionally walk if im in the office all day and the weathers fine |
ziglo Member Since: 20 Feb 2015 Location: channel islands Posts: 19 ![]() ![]() |
One other thing to watch out for is the build up of condensation in the engine due to small trips where the engine hasn't time to reach tempreture, you can check under your oil cap for this, I've seen it happen on a 330bmw and an Alfa.
Do you charge it with the battery connected and the car all locked and feed the charger wire through bonnet gap? Will 6mm eyelet comfort lead work or does it need 8mm? I'd like to top mine up once in a whilst parked overnight on the drive etc Ta Rob Visitor from fullfatrr.com * GONE. 2012 RR Sport HSE SDV6 Orkney Grey. Now being piloted by RRSTDV8 * GONE: 2011 4.4 TDV8 Full Fat. Amazing piece of kit. * Current. 1974 Lightweight 2.25L petrol. Old skool * GONE. Freelander GS TD4 Manual MY2013. Orkney Grey with privacy, cold and clearview packs, armrests (a must!) and a spoiler. * GONE. Range Rover Classic '93 200Tdi Factory fit * 1949 80" in family since 1975 |
Rob, do you have tow electrics? If so, you can charge through that plug using a CTek with adaptor. |
