Home > Technical > Suspension Lowering overnight - Now Fixed
Boost
United Kingdom 2007 Range Rover Sport TDV6 SE Zermatt Silver
As the title says, for a few months now whilst parked overnight the suspension would lower itself to the access height, It would always go back to normal after starting.
After reading up on here and a couple of other landrover forums I did a bit of fault finding....
The front end always lowered first (overnight) followed by the rear if left long enough, I thought one of the front airbags was duff. I confim this it was left at normal height overnight with battery disconnected, if an airbag was leaking one corner should have dropped. In the morning the front was lowered and rear was OK. This lead me to the front air suspension valve. Got a price for one, �68 + vat, but thought I'd check it out first, we used to strip solenods down at work when we had no spares and more often than not get them working again with just a good clean.
Had to wait for Santa to bring new trolley jack as the old one was a little the worse for wear now Very Happy
So yesterday I got busy, pulled the wheel arch liner back after removing a few screws & clips to find the valve;-
Squirted it with soapy water to check for any leaks
All Ok so removed valve to strip, mounted on rubbers in kidney slots, just undo pipes, electrics & push up to remove, undid four torx screws in valve to split body & get to inners
As you can see all the valve seats have some residue in, but the centre one loads more
The plunger end was covered too
This was all cleaned out with some solvent spray & dried with airline
The plungers were cleaned up
Then it was all reassembled & fitted back on.
Started to pump up then left over night with the battery on.
Checked just now and still all ok at normal height Very Happy Thumbs Up That's the cheapest fix so far. I intend to replace the filter & drier later on just for a bit of preventative maint :thumbsup:
Post #367847 Fri Dec 28 2012 12:45pm
Bradders
Great job - well done ! Thumbs Up FF 4.4 V8 Soooo looking forward to this bad boy
Ex 2006 RRS SC - garbage
Ex 2016 135i M Sport - dream car
Ex 2003 RS6 Avant - piece of cr*p
Ex 2014 320d X Drive, M Sport Touring - ok I guess
Ex 2007 RRS TDV8 - bloody loved it
EX 2007 FL2 XS - not so bad
Post #367850 Fri Dec 28 2012 1:02pm
kav1187
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
Great write up - thanks for sharing. I have added it to the definitive 'how to' thread Thumbs Up
Post #367856 Fri Dec 28 2012 1:54pm
panda
Bow down Bow down Great post Bow down Bow down
Post #367860 Fri Dec 28 2012 2:26pm
MBaker
Great write up. Thumbs Up
I take it you need to do a full deflate onto the bump stops before removing this?
Mike.
Post #465372 Mon Jun 22 2015 3:02pm
ABSport
United Kingdom 2011 Range Rover Sport 3.0 TDV6 Autobiography Santorini Black
Excellent write up.
Post #465376 Mon Jun 22 2015 3:13pm
Frax
Scotland 2012 Range Rover Sport SDV6 Autobiography Santorini Black
Great result and write up - like when people do their own work. Bow down
Post #465397 Mon Jun 22 2015 6:48pm
