Home > General > Squeaky Dash Pad |
Chillbrazil Member Since: 31 May 2015 Location: Portsmouth Posts: 85 |
Definitely a heat thing, creaked this morning then out again at 4ish after being in sun all day and no creaking
Sun Jun 21 2015 6:39pm |
ABSport Member Since: 14 Aug 2014 Location: Plymouth Posts: 698 |
Hi not known of any other issues, but the part your concerned about is very easily removed. Open the top glovebox and pull the left side of the dash ( centre part ) carefully pull out and lever it and it will come out. Only held in with clips. you maybe be able to stick some sticky pads behind to stop any rubbing or vibration. |
Sun Jun 21 2015 6:58pm |
Yeah as simple as that
Sun Jun 21 2015 7:29pm |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1941 |
ALWAYS use a plastic paint scraper, blade , spatula or wedge when removing any trim items, never a screwdriver. |
Sun Jun 21 2015 9:57pm |
Noted, thank you. Had a quick look and it will need a spatula type implement to lift off. Assume the switches and start button on the panel will have cables long enough to lift the panel off but not accidentally disconnect them.
Sun Jun 21 2015 10:31pm |
There is enough cable to pull off and disconnect the plug which feeds clock, start stop and other buttons. The clips won't break you'll be OK. |
Mon Jun 22 2015 5:49am |
