Home > General > Dynamic Stability Control |
RossM Member Since: 27 Aug 2012 Location: Poulton-Le-Fylde, Lancashire Posts: 80 |
How does the DSC work? Is it hydraulic? I'd always assumed it was part of the air suspension but having found a leak at the back of the car I'm assuming it's hydraulic and I have a leak on the rear part. Does it operate on the rear ARB? There seems to be a hydraulic motor or something like that but can't see properly. Looks like a trip to the garage! It's odd that it only seems to have started since my new air suspension compressor was fitted but pretty sure they can't be linked. 2007 Range Rover Sport TDV6 HSE- Cairns Blue with 22" Stormers |
Fri Jun 19 2015 5:49pm |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
It's just LR's term for traction control (applying the brake to a wheel if it slips) and is controlled by the Vehicle Dynamic Module (ABS Module).
Fri Jun 19 2015 6:05pm |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1068 |
Close but not right - what you describe is Traction Control but not stability control. To over simplyfy DSC like TC uses the ABS system but instead of detecting wheel slip it detects vehicle sideways or yaw movement in the vehicle and applies appropriate brakes to try to correct. You cannot turn Traction Control off as it is controlled by the TR system but you can turn DSC off and still have TC on. So it is not LR's term for traction control as DSC and TC are different systems just as ABS is a different system but all use the same components but in a different manner for different purposes. Garry 07MY RRS TDV6 Arctic Frost Aspen Interior |
Sat Jun 20 2015 2:07am |
Fair point. I was kind of thinking traction control without a capital "T" (if you get my drift), but you're right, a poor choice of wording on my part. Visiting from DISCO3.CO.UK
Sat Jun 20 2015 8:37am |
Streaky Member Since: 31 May 2010 Location: Dubai Posts: 259 |
So when would you turn it off?
Thu Jun 25 2015 12:48pm |
Wherever you are doing slow/technical offroad DSC should be turned off - basically offroad where any sideways motion is not going to be a danger to the vehicle - hi speed offroad it should remain on for safety reasons.
Thu Jun 25 2015 12:57pm |
