![]() | Home > Faults & Fixes > Tailgate |
harrygh60 Member Since: 16 Nov 2011 Location: London Posts: 395 ![]() ![]() ![]() |
Its the switch under the shroud over number plate. They get corroded and stp working. You can either take it apart and clean and give it a dose of WD40. I did that to one of my RRS and it was ok over two years when i sold it. Or to replace the switch cost about £22 on E bay itisme |
Simo1976 Member Since: 18 Sep 2014 Location: Kent Posts: 25 ![]() ![]() ![]() |
That's great thanks for the advise |
Powlesy Member Since: 23 Jul 2015 Location: Gloucestershire Posts: 1 ![]() ![]() ![]() |
Hi my glass tailgate switch stopped working, replaced the switch with a new one still nothing! Local dealer has said there is probably a broke wire in the loom so has advised to buy a new glass tailgate, seems crazy but can't work out how a new look would be fitted!!! Can it??? |
stagfinder Member Since: 17 Dec 2015 Location: Peterborough Posts: 22 ![]() ![]() ![]() |
how do you get the old catch out when you carn't open the top section so as to fit a new one in its place |
