![]() | Home > General > Black smoke |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9055 ![]() ![]() ![]() |
Usual "starter for ten" is to check the intercooler hoses for splits. 2012 SDV6 - it's missing a couple of cylinders
Dazlar Member Since: 13 Apr 2015 Location: Gloucestershire Posts: 9 ![]() ![]() ![]() |
Ok I'll check them and see if I can see anything..
Black smoke without the ESF is almost always a split in the intercooler hose or less likely a split in the intercooler itself. Bodsys Brake Bible
Thanks guys I've just been out to the car and found the split easy.. I don't know if it's the inter cooler hose but you might be able to help. It's at the front of the engine and goes of to left (drivers side) and is attached to a plastic thing with molded squares on it!!! ?? It's drops into the bottom of the engine can't see where it's attached down there, so must be a long hose????
That's the one. Easy to change. |
Thanks very much gonna order on eBay now..👍👍
I think that's the one that comes up from the intercooler - the box with squares on connects to the front of the electronic throttle and has the charge air temperature sensor in it (to measure the temp of the air coming from the intercooler). 2012 SDV6 - it's missing a couple of cylinders
