![]() | Home > Maintenance & Modifications > OEM Style LED Signature Halo Lights for 05-09 |
sparky8181 Member Since: 02 Nov 2012 Location: West Midlands Posts: 588 ![]() ![]() |
No worries Peter, I'm waiting on delivery of the wiring loom so will get a quote on postage as soon as I can put it all together in the same parcel. |
tanloverluke Member Since: 19 Mar 2013 Location: Honiton Posts: 917 ![]() ![]() ![]() |
Well Sparky came out with these lights and I had to try them. I have an unfinished thread regarding my angel eye modification and the reason why it's unfinished is because I was unhappy with the results. Sparky showed me the pics of his new rings and it gave me back the inspiration that I lost for the project. So I re-opened up the headlights and the result is as follows:
These are better than the dabhees ones in my opinion. There are far fewer resistors, just one for each led in fact, as opposed to the 9 or 10 in total on the dabhees rings. Whatsmore on Sparkys rings the resistors are hidden on the back surface, away from view. On the Dabhees rings the resistors are in full view and therefore aren't so aesthetically pleasing. Finally the finish on the ring, almost a black carbon effect, is very very nice indeed. I'm going to have to take a close up day shot. Overall better than Dabhees rings. That's my opinion anyway. Thank you Sparky! Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project. DONE: Meduza front bumper, AB rear bumper, AB tailpipes, calipers repainted, rear upper tailgate upgrade, side steps, AB front grille, AB side vents, rear LED lights, clear side repeaters, integrated daytime running lights, LED headlights. TO DO: color code sills and pillars. |
lamb190 Member Since: 12 Jun 2015 Location: bristol Posts: 80 ![]() ![]() ![]() |
wow that does look great. i too have been in contact regarding the LED units.
did you paint your light units black? |
yes I did lamb190. and polished the lenses. gives it an extra special look so well worth the extra effort. Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
what paint did you use? i plan to use some gloss black 2pack i have and some plastic promoter
I used a Java Black Land Rover color, keyed and primed of course first, then used a lacquer to finish off.
good stuff. time for me to have a play. |
day picture with lights off, showing the result of painting the internals.
kungfupanda79 Member Since: 19 Oct 2011 Location: Manchester Posts: 72 ![]() ![]() |
Sparky, have you got any of these led kits with wiring available? |
I have yes, I'll drop you a PM |
johnunleashed Member Since: 13 Jul 2014 Location: Lancashire Posts: 59 ![]() ![]() |
me too ![]() |
Nellyrs Member Since: 11 Jun 2015 Location: West yorkshire Posts: 3 ![]() ![]() ![]() |
These still available |
Yeah still available |
