![]() | Home > Maintenance & Modifications > fuel filter location...do I need to remove anything else? |
tanloverluke Member Since: 19 Mar 2013 Location: Honiton Posts: 917 ![]() ![]() ![]() |
I've been searching for the fuel filter and no luck. I've removed the engine undershield, and the other large grey plastic undershield ("transmission undershield"?) and I still can't see it anywhere. Is there anything else I need to remove before I see it? Apparently it's drivers side near the fuel tank cover, but can't find it anywhere.
The location changed on the 2.7 in the 2006MY - 2007MY changes.
As Paddi says, the later version is behind a vertical heat shield (not mentioned in the excerpt above). 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Thank you very much gentlemen. I'm going to have to locate the heat shield tomorrow and take some piccies once done. Updates to follow... Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
Thanks again guys! Found it behind the metal heat shield, which was held in place by three bolts. Took it off to reveal a non-genuine Land Rover fuel filter (thanks LR garage!) so on went the genuine fuel filter. Thank goodness I found the workshop manual that I thought has disappeared (this would also have lead me to the fuel filter), which detailed the correct procedure for fitting it. Half an hour jobbie. Well worth it. Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
ABSport Member Since: 14 Aug 2014 Location: Plymouth Posts: 698 ![]() ![]() ![]() |
A how too with pictures would be fantastic |
Oh yes. My RRS had a full LR service history when I bought it. So which LR garage fitted an undersized battery I wonder? I know which LR garage managed to forget to connect/tighten various pipes and fittings when they took the body off. Indeed, looking around my RRS, there's a history of bolts that have been lost or snapped off - notably the front bumper lower fixings and undertray bolts. I replace them when I find them and if I can remove the stub. At £100/hr I expect better... ![]() 2008 TDV8 - it was a labour of love and is much missed |
£100 per hour what a |
I don't take it there anymore; it goes to an indie now.
