Home > Faults & Fixes > Total electrical fail after hitting a bump! |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9013 |
Sounds like the vehicle thinks it's crashing. I'd have thought that a loose connection wouldn't reset without physical intervention. 2012 SDV6 - it's missing a couple of cylinders
Tue Mar 17 2015 10:48pm |
monty19 Member Since: 12 Mar 2014 Location: boro Posts: 323 |
check the battery terminals, i had this on a car i owned many years ago |
Wed Mar 18 2015 12:48am |
panda Member Since: 17 Jan 2010 Location: london Posts: 702 |
Sometimes my radio goes off for a second when I hit bumps,
Wed Mar 18 2015 8:56am |
Bladeboy Member Since: 17 Sep 2013 Location: Benson Posts: 522 |
I agree with Monty- I had the very same thing and one of my terminals was loose. Especially if fiddling about with the battery has happened. |
Fri Mar 20 2015 3:10pm |
frustrated Member Since: 15 Jun 2015 Location: SCOTLAND Posts: 2 |
Hello Alex. did you manage to source the cause of your engine failure. same thing happened to me 5 times this weekend
Mon Jun 15 2015 1:52pm |
alpaca Member Since: 09 Sep 2014 Location: Silicon Valley Posts: 83 |
If ECU was waterlogged - chances are there are other electrical issues caused by this sort of damage. Could be loose or corroded connection that shorts out when jolted anywhere in your system. I'd certainly start with battery and battery cables as well as ground straps (chassis) and alternator connections. Look for loose or corroded wires. But this may be hard to find and need I indie with electrical expertise to start measuring resistance on your wiring loom etc.
Mon Jun 15 2015 2:05pm |
Thanks, battery checked ok, will work backwards from there. LR guy seems to think it is something behind the dashboard.
Tue Jun 16 2015 8:19am |
