![]() | Home > Detailing & Car Cleaning > SNOW FOAM |
idrabble Member Since: 25 Oct 2013 Location: Brisbane Posts: 61 ![]() ![]() |
Plenty of posts here:
itsmeagain Member Since: 01 Nov 2012 Location: Birmingham Posts: 222 ![]() ![]() ![]() |
I use Ultimate Snow Foam and its very good but theres lots of different brands out there.
B9BS X Member Since: 19 Nov 2014 Location: Birmingham Posts: 420 ![]() ![]() ![]() |
Cheers for the link, might order a bottle. How many washes do you reckon you get on a 5 litre bottle? And do you just spray it on, leave it a while then wash off? RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
my bottle lasted ages. Just spray on and leave for a while whilst the dirt loosens and drips off. Then jet wash off
npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716 ![]() ![]() |
Spray on with snow foam lance and pressure washer
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2795 ![]() ![]() |
As above ^^^^^^ more of a gimmick than a cleaner |
Would u rinse the car first then snow foam or put the snow foam straight onto the dirty car?
I rinse the car first - then apply snow foam - followed by rinsing the snowfoam off - ( if this was all i was to do then I'd have a dirty Sport ) I then wash as normal |
Bilt-Hamber's Autofoam here!
Terryrrs Member Since: 25 Dec 2013 Location: Suffolk Posts: 158 ![]() ![]() |
Snow foam onto dirty car let it dwell to lift dirt and pressure wash off. Do not let it dry out and make sure all the foam is washed off. The theory of using snow foam is to allow the foam to lift the grit off the bodywork to prevent causing swirls but you still need to use a microfibre mitten to wash afterwards. |
I agree with Terryrrs, it's all about the dwell time. If you spray it onto a pre-rinsed car, the existing film of water is going to allow the Snow Foam to slide off. |
So just to conifrm...
