Home > Maintenance & Modifications > Brake switch adjustment
RogerDeFlor
Recently my wife was following me, as I was drive the sport, and after we had arrived, she asked me if I was riding the brakes, as after every junction, the brake lights would remain on for some time after I set off, as in "minutes".
So on my next trip, I started pulling up on the brake pedal after using it, and sometimes I could hear the faint click of what I assume to be the brake switch.
I've just had a look at the pedal and switch, and expected to find some way of adjusting it, but couldn't see any way to do it, short of bending the bracket. Is there anyway to adjust it so that it makes proper contact with the pedal ?
Post #464342 Thu Jun 11 2015 8:06pm
flack
No it needs replacing, they are only a few quid and 2 mins to change..
Flack Thumbs Up
Post #464346 Thu Jun 11 2015 8:56pm
harrygh60
England 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
Re: Brake switch adjustment
Dont go to a stealer,it will cost you around £100 supply and fit. The switch cost £20 Just a case of clip new switch in place and plug in itisme
Post #464365 Fri Jun 12 2015 8:56am
Lost for Words
http://www.advancedfactors.co.uk/xkb500030...-738-p.asp Thumbs Up
Don't release it before fitting and don't press the brake pedal when fitting it. Wink Visiting from DISCO3.CO.UK
Post #464367 Fri Jun 12 2015 9:03am
RogerDeFlor
OK, thanks for that, it's on order Thumbs Up Thumbs Up
Post #464376 Fri Jun 12 2015 9:53am
Paddi
Might be worth checking that the brake pedal pivot is not stiff or partially seized whilst you are under there?
The manual has a section on checking free play on the brake switch but it involves a dial gauge which most of us don't have.
Few tips on fitting the new switch:
http://www.rrsport.co.uk/forum/topic30757....dal+switch 2008 MY Java Black TDV8 HSE
Post #464383 Fri Jun 12 2015 12:17pm
RogerDeFlor
Cheers Paddi. Thumbs Up I did search for a post like that, before posting the question, but your post didn't come up in the results. I love the LR "standard" way of rotating the switch clockwise to undo it Rolling Eyes
Post #464392 Fri Jun 12 2015 2:41pm
