![]() | Home > Maintenance & Modifications > To Re-Map or not Re-Map that was the question...... |
And the answer is.........
MattMatt Member Since: 14 May 2015 Location: Swindon -ish Posts: 37 ![]() ![]() ![]() |
I've not had the RRS done yet (I've only just acquired it) but I did have a full power remap done on the Jag XF (same engine) and would agree wholeheartedly with the OP. Transforms the car completely especially in the 30-50 range. Worth every penny |
Well if you need it mapping, let me know |
sterling01 Member Since: 19 Apr 2015 Location: Kilmarnock Posts: 137 ![]() ![]() |
I'd be interested in how the MPG works out on a brim to brim on your regular normal driving. Current - 2020 Range Rover Sport P400e
Brim to brim mpg I always measure. The first tank won't be a true reflection of my normal driving whilst I've been errrr testing the increase |
Stu, yes, towing electrics need to be enabled. Different setting depending on if you are using 7pin or 13 pin electrics. |
aljo Member Since: 13 Jun 2006 Location: West Sussex Posts: 3243 ![]() ![]() ![]() |
Thought this was only possible if the ecu was mapped on the bench ? Are there plans for the 3.0 TDV6 to be remapped through the diagnostics port ![]() ![]() |
at the moment it is bench update only...... |
So maybe one day I might have a use for my MSV2 and possibly a remap courtesy of pete |
Not sure if the MSV2 will be able to, but other tools are constantly being developed. |
The MSv is fully supportive of Petes remaps.. I have had one on my car for three years now.. I did some testing with Pete the other week and had to remove my map.. what a different car without it.. as soon as I had finished the testing my remap was back on pronto.
Yeah, should have been clearer. 2010 needs bench update, msv2 has been able to do older Rrs and d3 for ages. Bodsys Brake Bible
