Home > Maintenance & Modifications > Hill Descent Control |
fkarim Member Since: 14 Apr 2012 Location: London Posts: 2216 |
Don't have in-depth knowledge but it uses ABS: https://live.landrover.co.uk/technology/la...technology
Mon Jun 08 2015 12:48pm |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
Very similar to cruise control really. It's controlled by the Vehicle Dynamic Module (AKA ABS module ) and uses the vehicles normal brakes. Visiting from DISCO3.CO.UK
Mon Jun 08 2015 12:50pm |
Member RRSTDV8 posted this useful document (which covers terrain response controls) a while back ... if you are interested. Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top
Mon Jun 08 2015 1:00pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8976 |
HDC uses the brakes to control the vehicle's speed. It controls individual wheels and makes use of the ABS wheel speed sensors to monitor what is going on at each corner. It's part of a suite of systems that make up the Terrain Response system.
Mon Jun 08 2015 1:47pm |
Black Bess Member Since: 09 Sep 2013 Location: Lincolnshire Posts: 245 |
Thank you all for such brilliant information. I am going to read the Graz paper on the way home (on the train, not whilst driving !!).
Mon Jun 08 2015 1:56pm |
Do you mean "Why can't a single wheel be turned when only it is off the ground?" by that?
Mon Jun 08 2015 2:53pm |
Doh !! I wasn`t thinking about it being in park. Will try that out when I next have the car on the jack. |
Mon Jun 08 2015 2:57pm |
Do you have the gearbox in park when you jack up one corner? That will prevent the wheel rotating. Have it in neutral (with the grounded diagonally-opposite wheel chocked to prevent rolling if necessary) and you should be able to rotate an individual wheel when its lifted.
