Home > Technical > Fault Code B1D21-13
Fault Code B1D21-13
Have fault code B1D21-13 Remote Control Switch - Circuit open. Says No Steering Wheel Remote In-Car Entertainment Switch pack Functionality. Now everything works fine on the steering wheel control, code clears ok. start car drive forward or backwards in straight line no problem and no code but as soon as turn steering wheel code comes back.
Possible Causes, Steering Wheel Switch Pack, Clockspring or Wiring Harness. Which do I go for first any ideas? I'm leaning towards Clockspring but open to any ideas/suggestions.
Post #463616 Tue Jun 02 2015 9:22pm
Lost for Words
Does sound like the clockspring is likely but ISTR the loom is quite cheap and it's usually suggested to start with that. Visiting from DISCO3.CO.UK
Post #463647 Wed Jun 03 2015 10:08am
Heremyjill
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Firenze Red
Col,
Just resurrecting this old thread as I now appear to have the same fault code showing!!
Did you ever get to the bottom of the issue?
If you can let me know I would appreciate it.
Alternatively, if anyone else has had this fault code and managed to rectify it.......
Thank you "Every Day is a School Day"
Now 2014MY RRS SDV6 AB
Now 2018MY Ford Fiesta ST Line 140bhp
Gone 2006MY BMW X5 3.0d Le Mans
Gone 2001MY BMW 530d Estate
Post #606697 Tue Nov 17 2020 6:55pm
Initially I never bothered about it anymore as never affected the audio at all, but later on I did fit a sports style steering wheel, while I was changing it I also changed the clock spring and small wiring harness which I happen to have in the garage and the fault code disappeared after that. So to be fair not sure if it was the clock spring or the harness. Personally if I was taking the steering wheel off to change the harness would change the clock spring at the same time or visa-versa.
Post #606704 Tue Nov 17 2020 9:38pm
