![]() | Home > Technical > CD player steering wheel controls sometimes swapping around |
Timf Member Since: 27 Feb 2010 Location: East Anglia Posts: 312 ![]() ![]() ![]() |
Interesting, mine does that too sometimes. No idea why but not often enough to warrant a trip to the diagnostics |
RRSSte Member Since: 03 May 2015 Location: Lancs Posts: 10 ![]() ![]() |
Yer I sometimes turn it off and it corrects it but would like to stop it doing it really |
frostmotorsport Member Since: 14 Apr 2014 Location: Wellington Posts: 79 ![]() ![]() ![]() |
it's the wiring loom behind the wheel. They get worn and cause buttons to do the wrong thing etc. Apparently you can remove them and solder them back up as a budget fix. I remember seeing a how-to somewhere, but can't find the darn thing right now!
oh cheers for that yer if you could find it that would be great 👍bet its a big job then 😒 |
nope. There are two holes on the backside of the wheel - you stick an L shaped bit of wire in there and that unclips the airbag. Remove the wheel (that's the bit I can't remember how) and then remove the loom etc.
