14jbs
I still have a problem with my 2008 RR TDV6 8 speaker Harman/Kardon audio system crashing and am desperate for assistance please.
To repeat - if turn on the car the audio system does not work. However, if I reboot the audio system by removing and replacing the fuse whilst the engine is running, the radio and CD player resets. I can then use both the radio and the CD player until I turn the car off. Then if I leave it for a while, such as overnight, the audio system crashes and the clock stops at the time that I open the car, or if unlocked, when I put the key in the ignition.
If I do not remove the fuse when the car is idle, the "dead" audio system must still be drawing power because the battery goes flat after a couple of days if not used.
I was advised by the local Landrover service center that I needed new audio head unit - costing around $3,000 which I was loath to do, so I replaced the audio head with a s/h one from Rover Triumph breakers, and I still had the problem. I sent that audio head back, they tested it in another vehicle and it was pronounced to be OK.
They again told me that they had come across around 20 RR Sports with the same problem and their auto electrician had to dismantle most of the wiring loom to find and fix the fault. They repeated that there were about five earth wires joined within the loom that they find to be corroded and causing the problem. Unfortunately they could not point me to any specific place in the loom to find the fault.
I do not want to mess with the loom, and so if I can I would like to run new earths from the audio head and if necessary the amplifier, but need a wiring diagram to help me work out where to run them from. Problem could be the wiring to the head or to the amplifier I suppose.
H E L P !!!
Fri Jul 10 2015 3:41am |
