Home > Technical > Help with suspension problem
crozzo
England 2007 Range Rover Sport TDV6 HSE Bonatti Grey
Help needed.
When driving along my RRS shows suspension fault light (amber). It then goes red and says special programs off. It then goes into no suspension at all and bounces over every little bump. I stop, turn it off and play with the suspension button going up down and so on for a while. This clears it until it does it again some miles later.
Any ideas.
Post #463205 Fri May 29 2015 5:57pm
Lost for Words
Is the amber light on permanently, or does it clear fully?
Do the heights appear normal on the 4X4 info screen?
I think fault codes may be needed to be able to diagnose it but let us know of any other symptoms and be as specific as you can. Thumbs Up Visiting from DISCO3.CO.UK
Post #463255 Sat May 30 2015 10:50am
fascinuk
United Kingdom 2006 Range Rover Sport Supercharged Rimini Red
this sounds familiar!! Roger
Post #463275 Sat May 30 2015 12:42pm
crozzo
Sometimes the front passenger side goes red and drops on the 4x4 screen.
Suspension is erratic after being stood for a couple of days
Post #463278 Sat May 30 2015 1:36pm
Lost for Words
Without further diagnostics, that would be my best guess then - a duff height sensor or associated wiring (Assuming the suspension still raises/lowers normally on that corner? Aside from when the full lowering is triggered, that is.)
If needed, the height sensors are available very cheaply from a few main dealers on Ebay and are easy to change (but the system needs to be calibrated afterwards): http://www.ebay.co.uk/itm/Discovery-3-heig...2ee12bbbea Wink
Post #463280 Sat May 30 2015 3:13pm
crozzo
Lost for Words.
Thanks for the advice mate. Had a mate of a mate who works for LR look at it today and he will take it in and check it out
Post #463304 Sat May 30 2015 10:38pm
