![]() | Home > General (L494) > Blanking TFT dash? |
robbo770 Member Since: 13 Nov 2013 Location: Aberdeen Posts: 248 ![]() ![]() ![]() |
Mark_N Member Since: 09 Aug 2013 Location: London Posts: 1102 ![]() ![]() |
Could also be a software problem which is causing the software running the display to hang up. Systems like this use a watch-dog timer which is continually reset by the software; if the software hangs up, the watch-dog timer expires after a few seconds and does a hardware reset. If the TFT dials do a new sweep when they re-appear, that would suggest a hardware reset is taking place. Mark
JSR2014 Member Since: 10 Feb 2015 Location: Kent Posts: 341 ![]() ![]() ![]() |
Mine has started to go a little odd, when the TFT is displaying the sat nav (coming up to a turn etc) the whole screen goes fuzzy and blurred - once its off the sat nav its fine....
x5pea Member Since: 03 May 2007 Location: Lanarkshire Posts: 2097 ![]() ![]() ![]() |
JSR, buy a wheel clamp before taking back to the dealer |
Chrisr1806 Member Since: 23 Jun 2013 Location: Sussex Posts: 683 ![]() ![]() |
Never happened on mine. Take it back to the dealer. Arrived: MY16 A/B SDV6 in Aruba, Ivory interior, piano black trim, black panoramic roof, spare wheel, blind spot monitoring, mudlaps and more... |
iainm Member Since: 20 Mar 2015 Location: Cardiff Posts: 48 ![]() ![]() |
Not happened on mine, bur switching between audio sources; mine has |
