![]() | Home > Technical > Installin 13-pin towing electrics from Bripart |
Ian.H Member Since: 04 Oct 2014 Location: England Posts: 180 ![]() ![]() ![]() |
I fitted a dual (7 & 13 pin) setup on mine (58-plate HST) (albeit from ebay).. didn't disconnect the battery. The hardest part for me was getting the wiring down behind the HST rear bumper... the rest was plain sailing.
Frax Member Since: 07 May 2015 Location: Aberdeenshire Posts: 241 ![]() ![]() ![]() |
Quite a good kit, just fitted one with no problems and I did not disconnect the battery, took longer to remove the panels than fit the kit, getting the wiring tidy was the hard part. Tail lights were also a bit of a pull to remove.
You can have both pics and text...
Nice one, wish I had seen this before I started, stuck my fuses behind the side panel ( not handy ) will need to move them now 😑 |
As for the tail lights not being the easiest to pull out, I found that too, so used a smallish flat-blade screwdriver and a piece if tissue (to prevent scratching the paint) and "prised" them backwards from the small gap between the front of the unit and the rear 1/4 panel... doesn't take much to shift them this way and no damage done |
jorn Member Since: 07 Jan 2015 Location: Ypres Posts: 39 ![]() ![]() ![]() |
Thx for The info.
I _think_ I removed both too mate.. IIRC, it was something to do with wiring up to the right-hand indicator.
Hi all
