Home > Faults & Fixes > Fault RRS tdv6 3.0 code P2263
Roberto Arenas
Spain 2010 Range Rover Sport 3.0 TDV6 SE Santorini Black
Hello Friends, I have a RRS TDV6 3.0 245hp of 2010 with 62,000 milles and when i go to 100-110 km/h ( 60-66 milles) keeping the accelerator pressed very soft i get the fault of restricted performance. The car is put into limp mode and i have to stop and turn on and the fault is removed. The machine gives me the fault P2263. That may be the problem? Change for some time the actuators shut off valve but the problems remain ...
In the diagnostic machine : P2263: regulation valve turbocharger boost pressure, control circuit signal amplitude very large upper
Help please Bow down Bow down ! Thank you very much
Post #462609 Thu May 21 2015 11:52pm
Workshop manual gives the following as possible causes:
Quote:
Air leakage post
turbocharger
Intake air
temperature (IAT)
sensor circuit high
resistance, short
circuit to ground,
short circuit to
power
Manifold absolute
pressure (MAP)
sensor circuit high
resistance, short
circuit to ground,
short circuit to
power
Mass air flow (MAF)
sensor circuit high
resistance, short
circuit to ground,
short circuit to
power
Exhaust gas
recirculation (EGR)
circuit high
resistance, short
circuit to ground,
short circuit to
power
VGT actuator failure
Turbocharger vanes
stuck/sticking
Not sure if that's helpful or scary... Big Cry 2012 SDV6 - it's missing a couple of cylinders
Post #463065 Wed May 27 2015 11:13pm
Roberto Arenas
Thank you very much !!!!!
I have been told that the fault comes from the turbo actuator
Morning give me the car Whistle
Post #463068 Wed May 27 2015 11:39pm
