Home > Technical > Fault Code Body B1B70 - B1 (28)
Peanut
Whatever I do this code always recurs!
Since getting my IID GAP tool I use it every couple of months just as a check.
I sometimes find codes which are explainable - P0191 23 (6Cool & P0625 11 (6Cool just after changing the fuel filter and not tightening it enough!
After checking for faults I clear them then check again the next day.
This one always recurs but I am not aware of any problems!
(I have a similar recurring code situation with Ventilation codes B1B74/5/6/7 but one thing at a time)!
I would appreciate any guidance on whether this is indicative of a real problem I ought to investigate further or can just ignore.
Post #462992 Wed May 27 2015 8:05am
Lost for Words
If there are no symptoms, ignore it. Thumbs Up Visiting from DISCO3.CO.UK
Post #462993 Wed May 27 2015 8:10am
Fault codes related to the motors that drive the flaps that direct air to the various vents in the dash/footwells.
I've noticed that I get weak air flow to the rear seats and that I get similar error messages (always 4 of them) on my IID Tool. I rarely use the rear seats so haven't chased the issue but I think at some point a new motor or two behind the dash will be required. 2012 SDV6 - it's missing a couple of cylinders
Post #463064 Wed May 27 2015 10:56pm
