![]() | Home > In Car Electronics > Alarm sounding without reason |
It needs plugging in to diagnostics which will tell you what is triggering the alarm. 2008 G4 RRSport TDV8 current
wemeadows Member Since: 22 Jul 2013 Location: Washington State Posts: 21 ![]() ![]() ![]() |
I had a similar issue with my old Rover. It was the bonnet-closed sensor button failing and it drove me crazy.
johnunleashed Member Since: 13 Jul 2014 Location: Lancashire Posts: 59 ![]() ![]() |
As above bonnet-closed sensor , common problem , it is on the left side as you look at the engine , just bypass it and see if it sorts the problem , if so then get a new sensor 2007 SUPERCHARGED HST |
Robfellows Member Since: 02 May 2013 Location: Wolverhampton Posts: 10 ![]() ![]() |
Thanks everyone, wil look at the sensor Rob |
