Home > General > Can these be replaced |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4981 |
You could try searching these L/R Part Numbers LR018086 and LR018089 not sure it's what you are looking for but may point you in right direction. I don't think you can get the name plates separate unless you buy accessory tread plate kit.
Sat Mar 21 2015 9:19pm |
Garage Door Medic Member Since: 02 Feb 2014 Location: North West of UK Posts: 197 |
Thanks COL for the info, but the bits I am after, are the stainless steel Range Rover bits and the plastic trims they attach to, they run from the front to the rear both sides, been googling inner cill trims and other names, it's going for a service on Friday may see if they can name them MY 13 3.0 SDV6 HSE Black Edition
Tue May 26 2015 7:09pm |
You need to search for sill tread plates and then you can find the originals here:
Tue May 26 2015 7:19pm |
Thanks Paddi, it's not just the stainless Range Rover badg, it's the plastic trim that they sit in as well, passenger door one is not sitting flush to the carpet and the stainless bit is bent, looks like previous owner has for some reason just yanked them up and slightly bent them so I am thinking replace them both sides, MY 13 3.0 SDV6 HSE Black Edition
Tue May 26 2015 8:53pm |
According to the L/Rs Microcat parts lists the description is Panel, R/H, Inner Lower, "B" Pillar, Tread Plate Stainless Steel, Interior Ebony Carpet. Part Number LR018086 The Name Plate is not listed separately. For the opposite side R/H is simply replaced with L/H. Part Number LR018089.
Wed May 27 2015 6:20am |
x5pea Member Since: 03 May 2007 Location: Lanarkshire Posts: 2097 |
Easily replaceable , I swapped the std ones for autobiography ones on my sport.
Wed May 27 2015 7:59am |
Thanks Col & X5pea these have been bugging me since I bought it, and been searching for ages, will order with the clips. MY 13 3.0 SDV6 HSE Black Edition
Wed May 27 2015 7:22pm |
ABSport Member Since: 14 Aug 2014 Location: Plymouth Posts: 698 |
I can confirm the original Autobiography interior side sills Are £46 each side brand new from JLR. I fitted them them to mine brand new |
Wed May 27 2015 7:41pm |
Just remembered have a feeling the actually came with new clips fitted but not totally sure.
Wed May 27 2015 8:52pm |
Thu May 28 2015 9:03pm |
Thanks Col, ordered them and fitted them today. These have been bugging me since I got the car, I can't see why they have been damaged, but now they look as they should do, very easy to install, I did order the clips as well, but they came with clips. MY 13 3.0 SDV6 HSE Black Edition
Sun Jun 07 2015 8:04pm |
