Home > General > Sat nav, phone and audio stopped working 2007 tdv8
robbietdv8
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
hi I'm hoping someone can help as i'm a neebie to posting but have already found loads of post that have proven helpful.
so here's the situation i have a 2007 tdv8 which in all fairness i had allowed a few problems to amass, untill last week when in my wisdom i decided to have everything fixed, front arms , new compressor as i had the yellow light of dreams for about a year.... with some help from here all done fine the last problem as the parking sensors had stopped working but this really the start of the problem, having been told the parking sensor unit was in the boot drives side i have now found out its passenger side....
but i think i have disturbed or knocked the nav or phone unit!!! everythings connected i have check and i can see the red light in one of the connectors..
fault reader says to check i have nav, phone, audio installed ....which i do as it worked until Big Cry yesterday
could it be something simple like a fuse and if so what fuse does the nav work off and would it not have stopped everything on the dash working? as i still have the back light land rover sign and the radio comes on just no sound...
i hoping one of you range rover tec gods has a quick fix
thanks in advance
Robbie
Post #462936 Tue May 26 2015 3:33pm
Bladeboy
England 2005 Range Rover Sport TDV6 HSE Siberian Silver
When I got a new BT
module I reconnected one of the leads the wrong way round. The result was no sat nav, no audio and no phone. If you have disconnected the BT module on the drivers side of the boot it might be worth swapping the leads round mate.
Post #462948 Tue May 26 2015 6:44pm
robbietdv8
thanks i'll give it a try in the morning
finger crossed
Post #462955 Tue May 26 2015 7:35pm
robbietdv8
just checked everything is plugged in and the red light can be seen in the fibre optic wire but only going in to the silver box , it doest come back out and go into the nokia box
does any one know what the silver box is and could this be the broken link in the chain as from what ive read they need to be a link between them all
cheers any help would be gratefully received Shocked the wifes going made with no music
Post #463002 Wed May 27 2015 11:15am
Lost for Words
That's the TMC (Traffic Message Channel) module so could well be related to your problem. Afraid I don't know enough about the "infotainment" systems to help further. Visiting from DISCO3.CO.UK
Post #463009 Wed May 27 2015 12:21pm
robbietdv8
many thanks for all your help guys, having been lost for idea i started at the beginning checking fuses one by one again #42
was blown , but you couldn't see it had blown only found out by luck.
so it just the parking sensor issue to fix
any one wana help Rolling with laughter
Post #463011 Wed May 27 2015 1:14pm
Bladeboy
The problem I had was the wire with the White clip on on the black box to the right of the tmc box
Post #463019 Wed May 27 2015 3:38pm
