![]() | Home > Detailing & Car Cleaning > Piano Black Interior Sctarches |
x5pea Member Since: 03 May 2007 Location: Lanarkshire Posts: 2097 ![]() ![]() ![]() |
anyone got any ideas? |
Chrisr1806 Member Since: 23 Jun 2013 Location: Sussex Posts: 683 ![]() ![]() |
Sorry can't help, but would also be interested in suggestions as I have the same problem. Arrived: MY16 A/B SDV6 in Aruba, Ivory interior, piano black trim, black panoramic roof, spare wheel, blind spot monitoring, mudlaps and more... |
JSR2014 Member Since: 10 Feb 2015 Location: Kent Posts: 341 ![]() ![]() ![]() |
I have heard that Autoglym Super Resin Polish does a nice job, I used some on the Piano black on my XF and it came up well, however that may have just been a fluke so would suggest that you try it somewhere not noticable first and I cannot take any responsibility should the SRP harm the surface any more.
Invincible Member Since: 13 Oct 2014 Location: Stigenace Posts: 64 ![]() ![]() |
Try Poorboys Black Hole. It works on the exterior shiny plastic parts. 2015 - HSE Dynamic - Santorini - Stealth Pack
Argonaut Member Since: 04 May 2015 Location: Hampshire Posts: 6 ![]() ![]() ![]() |
I used Menzerna Super Finish on mine, and it's done a great job. Needs a lot of elbow grease to get best results, it's a very, very fine polishing compound. |
edviss Member Since: 29 Feb 2016 Location: london Posts: 28 ![]() ![]() ![]() |
These trims can be polished out as they have layer of laquer on top. |
CANROVER Member Since: 03 Oct 2015 Location: Ottawa Posts: 255 ![]() ![]() ![]() |
The piano black interior has a laquer coating very similar to clear coat. To start, I'd recommend using a light clearcoat polish like Zymol cleaner wax as it is a combination, polish and wax all in one. The goal is to take off little by little to avoid overdoing it and taking off too much of the clearcoat layer.... If the cleaner wax is not enough, go with a light polish or try Meguire's scratchX 2.0 as it is a small area. After you've removed the scratches make sure to protect it with a coat of wax and sealant to really bring the shine out.
