Home > General > Suspension hight
Frax
Scotland 2012 Range Rover Sport SDV6 Autobiography Santorini Black
Suspension hight
Hi can anyone advise as to how long the car should hold its hight.
I have just got a 2007 RRS and do not drive it every day - it sits in the garage and after about 3 days starts to slowly drop. Have I a leak or do they all do this over time.
Regards
Post #462257 Mon May 18 2015 8:23pm
Try the advice regarding fuses etc. in this topic:
http://www.rrsport.co.uk/forum/topic39319....nsion+fuse
This will help establish if it's a controller / ride height problem or an air leak. With the system electrically switched off there shouldn't be a level change. If there is, that points to a leak somewhere. 2012 SDV6 - it's missing a couple of cylinders
Post #462259 Mon May 18 2015 8:33pm
Frax
Thank you for that will go and have a read Wink
Went out and started her up, back was down. Let it sit till it got to correct height and pulled fuse 26 so will wait and see what happens.
Will be phoning the garage it came from in the morning and get it back in and checked. Sad
The front stayed up and only the back had went down.
Will update tomorrow.
I have only had it a week Big Cry
Post #462261 Mon May 18 2015 8:36pm
Frax
Checked it this morning and it is still sitting at its height.
Do you think I need to replace both back height soncers or would a calibration sort this out, mind you it sits fine when running.
Stange that it takes so long to drop.
I have also seen people speeking about access mode, ??
Post #462297 Tue May 19 2015 6:16am
