![]() | Home > General (L494) > Oh Dear ! |
Fletcher Member Since: 28 Jan 2015 Location: Devon Posts: 481 ![]() ![]() |
Wow . That is a bad luck story . Well I hope it is just bad luck and not the shape of things to come, I was thinking roll on September buy not sure what to think now .
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9017 ![]() ![]() ![]() |
Threaten to return the car as unsuitable and for a full refund. I bet they'll sort it out quickly for you then! 2012 SDV6 - it's missing a couple of cylinders
RAUNS Member Since: 18 May 2015 Location: Leeds Posts: 7 ![]() ![]() |
Hi Fletcher
sterling01 Member Since: 19 Apr 2015 Location: Kilmarnock Posts: 137 ![]() ![]() |
You have spent a heck of a lot of money on a car. If I were you, I would reject it as not fit for purpose and ask for a new car to be supplied. Current - 2020 Range Rover Sport P400e
peanutbob Member Since: 04 Jul 2011 Location: UK Posts: 585 ![]() ![]() |
If it's any help my 2013 L494 had a similar issue, in that under warm conditions with the air con on max cooling, the climate would cut out. However, in my case the blower ceased to work hot or cold. Only resetting the climate from on to off and then on again, would it restart. The dealer found no fault, but I concluded that it was a faulty interior sensor as from some older posts, this was an occurrence on recent prior shape RRS cars. So, you could try going into the climate settings and swapping from on to off and then on again. Since I collected my 2015 model at the end of April , the weather hasn't been warm enough here to test out the air con on full whack.
peanutbob
robbo770 Member Since: 13 Nov 2013 Location: Aberdeen Posts: 248 ![]() ![]() ![]() |
email Pete |
bermyandy Member Since: 09 Sep 2007 Location: London Posts: 336 ![]() ![]() |
We had the exact same air con issue on our car (Dec-15 delivery). Would get around 15 minutes of cool air, but only if you had it on max cool. After that you'd get the outside air.. - car spent around 3 weeks in the dealer trying to fix it, eventually narrowed it down to the compressor but like you there was a delay in the part. It was meant to be fitted last week, which we didnt do in the end so can't tell you if that fixed the problem, but thats another story |
Buster007 Member Since: 02 Dec 2010 Location: Essex Posts: 649 ![]() ![]() ![]() |
RAUNS January this year I picked up a new Audi RS4 within 3 weeks of ownership I had a paint problem Audi wanted to re-spray the front end of the car which I refused!! They told me that was my only option! I read the small print on their invoice which said if I wasn't happy with the car within 30 days of purchase I could return it for a car of similar value. I took it back and asked for another one Audi agreed I could have another one but said it would take 5 months to arrive as they would only give me a factory order car! I demanded a full refund and got it!! Might be worth taking a look at what they have on their forecourt and in group stock, make some enquires and mention you are considering returning the car! As Fletcher said 'hope it is just bad luck and not the shape of things to come' Cheers Laurence. |
mcgroa Member Since: 08 Dec 2014 Location: UK Posts: 23 ![]() |
Any connection to the recall for wiring loom due to possible shorting issues at max cooling? |
TDV8AB Member Since: 19 Oct 2013 Location: Uk Posts: 32 ![]() |
Sounds like it's linked to the wiring loom campaign.
Ian J Member Since: 11 May 2015 Location: Midlands Posts: 10 ![]() ![]() |
The car may be built in the UK but that doesn't mean that the parts are also made here. One of my neighbours is an engineer working for JLR and he is responsible for overseeing the production of just one part of the car and he seems to spend most of his life in various factories in Eastern Europe |
philmw Member Since: 18 Aug 2006 Location: Nottingham Posts: 1672 ![]() ![]() ![]() |
The cars are built just-in-time, with less than 4 hours stock on site. Parts are delivered to the station as they are used, and is an amazing logistical and scheduling triumph. Remember ILR are building four different models on the same line at the same time. This is why orders are locked down a month before build. With this in mind, getting a new part in 10 days doesn't seem so outrageous.
