Home > In Car Electronics > LOCATION OF SAT NAV PLAYER
TOELPEL
Spain 2005 Range Rover Sport TDV6 SE Buckingham Blue
I have The 2015 NAV cd for updating my Nav system but can't find the player. It is not installed under the forward seats.
I have a RRSRT TDV6 HSE of 20015.
Can anybody help
Post #462049 Sat May 16 2015 12:52pm
Are these vehicles not updated via a memory stick plugged into the usb port same as 12/13 models? seems a retro step if they have gone back to a disc.
Post #462050 Sat May 16 2015 1:38pm
riverblanche
if its a 2005 tdv6 2.7 as your profile Question
then it should be IIRC under the front left seat behind a cover panel (n/s/f on a uk car!)
if you have a 20015 Rt then I have no idea Whistle
Post #462060 Sat May 16 2015 6:41pm
Oops! misread the post thought he had a 2015 Sport.
Post #462068 Sat May 16 2015 7:40pm
darrenmcneill
England 2006 Range Rover Sport TDV6 HSE Tonga Green
Does this RRS fly?? That's well in the future! Rolling with laughter 2006 HSE for Sale - £7,499 (Manchester)
http://www.rrsport.co.uk/forum/topic46383.html
Post #462076 Sat May 16 2015 8:52pm
TOELPEL
Sorry for the mistake. The RRS is of 2005 and there is no player under the front seats.
Post #462124 Sun May 17 2015 7:09pm
Bodsy
Site Sponsor
So if you move the front seats all the way forward and up, what can you see under the seats? One side will be an amp and the other side will be the Satnav DVD drive. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #462125 Sun May 17 2015 7:16pm
TOELPEL
I'll come back wit photos to show what is under the seats. There are two units, one under each seat, but none has a slot to insert a CD.
Post #462134 Sun May 17 2015 8:37pm
Bodsy
Site Sponsor
On, so the one that has a blue plug in it, yo need to reach over the top of it, press the button on the front right hand side. If the button doesn't press in, move your hand to the left hand side and slide the slider over, then press the button again. The disk will slide out, replace if you have another disk and it will go in ok. Thumbs Up Thumbs Up Bodsys Brake Bible
See it HERE
Post #462135 Sun May 17 2015 8:56pm
TOELPEL
Thanks BODSY . Under the driver's seat (LH) is indeed a box with a blue connector. On lable on it reeds DENSO.
The button for ROM out and for lock/unlocking are not on the unit itself but about 2" away from it. These can only be accessed from the front after removing a black plastic cover. From the front position one can see the slot for the CD, but the CD will not
slide out completely because a bracket is obstructing it. In my case I will have to take the whole unit out from the back of the driver's seat by unscrewing 4 little bolts. The cable are long enough to perform this task.
Again thanks BODSY, you are a big help.
Post #462204 Mon May 18 2015 2:09pm
Bodsy
Site Sponsor
I think something is stopping your seat from moving all the way forward.
But, you found a solution to the problem Thumbs Up Bodsys Brake Bible
See it HERE
Post #462205 Mon May 18 2015 2:13pm
TOELPEL
The seat moves forward and back, also rises. The bracket holds a plate on which are some electric parts are installed. This bracket is in the way to fully let the CD slide out. Anyway it is a not understandable why Land Rover blocked the CD slot in that way.
Post #462213 Mon May 18 2015 3:26pm
TOELPEL
SOLUTION:
TO unload or upload the DVD I have to move the seat forward in order the bracket to clear full access to the player. I changed the 2005 DVD with the 2015 one and all works fine. I did not use the Program disc which was delivered together with the 2015 one. Thanks to all: what a great place this forum is!!
Post #462695 Sat May 23 2015 11:24am
Landyrover
Hi, I'm trying to do the same thing but no luck so far. I've moved the seat forward and up but can't see or feel any buttons. There's a black plastic cover under the front of the seat which I guess is covering/protecting the slot and buttons, but there doesn't seem to be an easy way to remove this...
Any further suggestions please?
Thanks,
Nick
Post #462786 Sun May 24 2015 2:04pm
TOELPEL
Yes, you have to remove the black plastic cover. It has for clips , two on each side at the top and two at the bottom. Try to get the top off first and then the bottom ones, perhaps one at a time. With the seat in the most backward a position you reach the black cover easiest and you can locate two buttons on a black housing. Push one to the left ( there is padlock open on it and then push on the left one labeled ROM. This one will slide the DVD out,, which will only slide out completely when you move the seat back fully forward. Once you have the old DVD out slide the new on in. After that slide the button with the closed padlock on it to the close position and you are done. Then put back on the black plasti cover with the four clips. Good luck.
Post #462790 Sun May 24 2015 2:42pm
