Home > In Car Electronics > 2006 RRS CD player not working
mr_spaceuk
Hi I have an issue with my 6CD player - its says there are no CD's in it, but it wont take in a CD. The CD hardly goes in and feels like its hitting something.
I got a feeling something may be jammed or something like that.
Help please!
Post #462062 Sat May 16 2015 7:07pm
riverblanche
seem to remember we had something like this
but it just turned out to be how you try and load the CD
make sure you have selected CD and select number 1 of the 6 CD choices then it should load
I am working from memory so you may have to "read between the lines" a bit Rolling Eyes but if all the icons are showing as MT it will not load until you select one first
Post #462120 Sun May 17 2015 5:01pm
Bodsy
Site Sponsor
You've selected CD as the input and then pressed number 1? That will then tell you to insert disk. It won't let you just put them in.
Also, if you hold down the eject button and keep it held down, it will eject all 6 disks one after the other. Not sure if it does the same for inserting all 6 cd.s.
Failing that, I've just installed a double din unit for someone and they have a working CD module from thee head unit that could be swapped over they may be interested in selling? Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #462126 Sun May 17 2015 7:21pm
mr_spaceuk
Thanks guys, this info was really helpful.
I had no idea that I had to choose a CD 1-6 and then insert the CD.
Having said that I also just found out that I had electric folding mirrors after 2 months of ownership! Rolling with laughter
Post #462362 Tue May 19 2015 6:21pm
riverblanche
the other favourite is not knowing you can set how far the mirrors dip when you select reverse Rolling Eyes
so they get turned off instead, Whistle
I am sure I learn something new each time I take it out, but then again it could be because I forgot what I found out last time Laughing came home last night and forgot I had set "homelink" for the garage lights Confused
Post #462492 Wed May 20 2015 5:43pm
mr_spaceuk
Christ On A Bike!!!! You can change the tilt on the mirrors too??? I turned mine off as they pointed at the ground and not at the rear wheels like I wanted.
If the manual wasn't the thickness of War & Peace, I would read it!
Post #462497 Wed May 20 2015 6:34pm
